RADV (as Default) and AMDVLK
Hello!
So I am in an odd spot. RADV is awesome and I want to use it by default. All good I have that with Fedora.
Now there are games especially newer ones where amdvlk maybe runs better/features do not need to be disabled.
So I went ahead downloaded the rpm installed it.
Relogged my session and now all my GTK Apps have black bars around them. OKAY. Probably amdvlk doing… something.
So going by How to disable RADV driver?
I thought if I would just
export AMD_VULKAN_ICD=RADV then the OS would default back to using RADV but this is not the case.
I also expected to see other files in ls /usr/share/vulkan/icd.d/ like additional ones.
So I am a bit confused on what to do. Info is somehow hard to find for me.
I wish to be RADV the default unless I specifically would enter AMD_VULKAN_ICD=AMDVLK into steamgame commands.
I saw amdvlk will assume “control” once installed. I basically want to invert this towards RADV instead.
Uninstalling obviously reverts it since the black bars are gone once I do.
Which is my terrible workaround at this very moment.
This is also a super fresh Fedora41 install. Basically no changes.
Hopes are some people here know 100% what to do. I usually only lurk around^^
Okay I figured out amdvlk64.so gets placed under /usr/lib64/ from the rpm.
Once it is it appears to be loaded on session start.
I am not sure. I extracted the amd_icd64.json.
It has a entry towards the amdvlk.so file. I placed this one in my home directory and changed the path of the json but that doesn’t appear to work. As mentioned I basically have no clue what I am doing here.
I hoped VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/amd_icd64.json would work.
