Hi all,
I’ve recently swapped out my secondary GPU (RX590) for a Radeon VII. So I now have a 5700XT and a Radeon VII in my box.
I’ve setup the vfio bits the same as I had for the RX590 but now for the Radeon VII but whenever I try to boot any VM on the Radeon VII the GPU doesn’t seem to initialize. I have checked the firmware on the VII and it is the latest so it’s not the UEFI issue I think.
I’ve tried both with Linux and Windows guests, tried updating the AMD drivers on the Windows guest as well. The gpu shows up in the hardware information but says that the device had to be stopped due to hardware issues.
Is there anything else for the VII I need to do to get it to work with vfio? Alternatively I can swap the GPUs and use the 5700XT as secondary, I was kind of planning to do that anyway but now the fact that I can’t get the VII to work is bothering me.
Thanks!
- HP
