I purchased a radeon r7 260x as an upgrade from my old radeon hd 6670 and it runs fin untill i go into games where after about an hour of playing my screen goes black and requires multiple restarts in order to get back into windows.
i am running amd catalyst 13.12 and have not overclocked the card
System specs? To you meet the power requirements of the new gpu?
Are your temps in order?
Is your cpu overclocked and stable > go here http://www.ocbase.com/ and run a stability test on everything.
If you are able to test the card in another machine, great. If it works well in that then there is a fault with your setup if it fails then RMA the card immediately.
