So, in these days you can find some 32GB Radeon Instinct MI50 for around 200$, which seem quite a bargain if someone wants to experiment a bit with AI for cheap.
So I bought one, and here are some random notes from my journey to use it.
First, MI50 is no longer supported in ROCm - latest version that supports it is 6.3.3.
Also, after struggling to get the amdgpu-dkms compiling on 24.04 i switched to 22.04 with 5.15 kernel.
So, here are more-or-less the steps I followed to make it work.
First, pass the MI50 to the VM in the usual way, nothing strange here. But you’ll need to vendor-reset dkms module, otherwise the MI50 won’t work properly in the VM.
Second, no spice video: rocm seem to get confused when there’s a virtual GPU in the system and tries to use it - but failing miserably to do so and switching back to the CPU. Setting various environment variables like CUDA_VISIBLE_DEVICES didn’t work either.
After setting up the VM, install ROCm 6.3.3:
wget -c https://repo.radeon.com/amdgpu-install/6.3.3/ubuntu/jammy/amdgpu-install_6.3.60303-1_all.deb
dpkg -i ./amdgpu-install_6.3.60303-1_all.deb
amdgpu-install --vulkan=amdvlk --usecase=rocm,lrt,opencl,openclsdk,hip,hiplibsdk,dkms,mllib
After that install ollama 0.12.4 - later versions don’t support MI50 anymore; maybe it will work again with Vulkan support, but it’s still experimental and you’ll have to compile it yourself.
curl -fsSL https://ollama.com/install.sh | OLLAMA_VERSION=0.12.4 sh
With this you should be good to go (hopefully
Hope it helps people also trying to use this card ![]()
Bye
Andrea
PS: I also tried llama.cpp, but it segfaults when trying to run a model.
