So I have an interesting situation with my 7950. I've had this card for almost a year now and haven't really had any problems with it until recently. It's clocked at 925mhz, stock clock, but it's having problems with Garry's Mod for some reason. I looked at temps and everything but nothing seems out of the ordinary except the GPU usage was only around 20% - 35%. For normal play it's not really an issue but when I try to record FPS drops drastically and like I said before this is a new problem. Any help would greatly be appreciated.
you have to block the fps, i use dxtory and the fps is always blocked at 50
Try changing the settings, in launch options -dxlevel 98 and in console something like mat_compressedtextures (I noticed if you change this from 0 to 1 or other way around, the graphics card was used more.)
What program are you using to record or are you using a capture card? If you're using a program, you may want to check the settings and see if your FPS is capped to a certain number for recording. Also certain games don't like certain programs. I also have a 7950 and when recording Unreal Tournament 2004 I don't get FPS drops but when I view the video it's like a slide show. I get something similar with Skyrim as well. I use fraps btw.
I'm starting to get the feeling it's not the recording program but something with my graphics card. When I first got it I had no problems running minecraft with extreme render distances (normally like 90+ fps) but now I have it rendering at the smallest distance and I'm not even at 60. I don't understand what's going on.
bump
Probably windows. Or drivers.
That's the thing, I did a complete system restore. Installed fresh drivers and windows and everything. Yet still having problems. Sense I don't have all my games like before I can't test them all but Garry's Mod still has struggles and I just got Rust today and it seems to have problems too, but since it's in early beta I would give it the BOTD.
Ignore my bad grammar.
So interesting idea here, and it was probably a dumb move in the first place but today I upgraded my hard drive from a WD Caviar Blue 500Gb to a WD Caviar Black 1Tb and in the process switched my OS from Windows 8.1 to Windows 7. Either one of those could be a contributing factor but things seem to be working properly. I'll keep playing and updating on how things work out.
