I can see that they have different Clock Speeds, but other then that? - is there going to be a big performance difference between these three cards?
Can some one help me figuring out which one should I buy? I was thinking about number 1 as it has 2 fans and number 3 has only 1. Is the Gigabyte really worth the money in compression with the other two?
I think the first MSI model and the Gigabyte versions are both great options. Are you overclocking or do you want it stock. If you want stock then pick the cheaper of the two. Otherwise, go for the better cooling option.
