Right now, after some previous recommendations from you guys, I switched my previous HIS Radeon HD 7870 to the Sapphire 7870 GHz edition to cut about 30$ off the price without any apparent difference in performance--am I right in saying that? By the way, what's the difference between the regular and GHz editions?. I want to play BF4 at relatively high settings on this, and DICE released info that suggested at least a 7870 with at least 3 GB of storage, but I can't find any 7870's with 3 GB of memory. Do I really even need that much, and if I do, are there any other comparable Radeons at that price that have that?
My budget is 1,000$, and I'm a bit over at the moment, but I definitely can't go all the way to 1,100$.
Also, if you have any other general recommendations for my build, let me know.
The 7870 is a very good card and can push most games to high/ultra settings at 1080p.
I don't believe you really need that much memory for that game, but not sure. Either way that card should run it fine. At that price it is a very good deal too considering how expensive AMD cards are going for right now.
The main difference between the regular version and the Ghz Edition is the clock speed. Ghz Edition cards have a clockspeed at or higher than 1000Mhz, or 1 Ghz. You can simply overclock a regular code to over 1 Ghz easily most of the time.
there's no such thing as a non ghz edition 7870, ghz edition means that the gpu core comes clocked at 1000mhz/1ghz or more
if you're looking for saving money the 7870, r9 270, and r9 270x are all the exact same graphics card with different stock clock speeds, 270 being an underclocked 7870 and 270x being an overclocked 7870, if you're overclocking regardless you should be able to get the same performance regardless of which varent you get
I have that same 7870, it handles BF4 just fine. Friend of mine bought it as well, he has no issues. It is voltage unlocked if you care about overclocking.
Especially with Mantle right around the corner (the runtime comes with the next driver update, I believe), a 7870 will do about as well at BF4 as any other card at 1080p60.
