Radeon HD 7790?
I was just wondering if the HD 7790 was worth the price and if it could handle BF4 at High settings?
720p yes, 1080p depends on the map and amount of players.
The 1gb version is 109 right now should I just save $30 more and get the 2gb 7850? My res is 1366x768 (terrible I know).
At your resolution, the 7790 will definitely handle medium settings. A good possibility it will handle high. I would grab a 7850 (either 1gb or 2gb variant) to play high settings at 1080p.
The 7850 is worth the additional $30.
+1
Thanks for all the help! I'm just looking for the cheapest GFX card possible that'll run it at High at 720p.
I will say 720p high-medium settings with 60fps (assuming your cpu is not bottlenecking)
CPU is an AMD FX-6300
With a FX6300 and 7850, you will easily achieve high at 1080p. I really would suggest upgrading your monitor.
The price difference between the 7790 and 7850 is so small. I wouldn't say the 7850 was too much for 720p. It will probably run ultra quite comfortably.
hard to find benchmarks at this low rez(1366x768) the 1680x1050p is the closest. (so if we extrapolate the HD7790 at 1366x768 should get around 60fps with high-medium settings)
your cpu btw is fine you will not experience any bottleneck.
Probably stock performance benchmarks. Which means he could probably get a bit more performance out of any given card.
Thanks for all the help guys! I think I'm gonna go ahead and pick up the 7850.
Also anyone know what PSU would be good enough for a R9 270 non x
