I am building a pc for the first time and i would like to get a graphics card that works with adobe premiere. I would rather not spend the money on nvidia card. will any amd radeon cards work with adobe premiere?
If you're using CS6, then a 7970 or 7950 are the way to go.
they will work, but they won't take advantage of the cuda acceleration.
thank you
No problem :)
get the nvidia. cuda makes a big difference.
