Radeon 7870 vs 7950
As the title says,which one has the best value in the long run? Which one has the better price/performance ratio? Is the $50~$70 worth the extra performance?
what ratio are you wanting to game at?
I'm not planning to do any rough gaming,online FPS games such as Counter Strike and stuff at most.
better value in the long run is deffinatley the 7950, price / performance ratio is slightly better for the 7950 in opinion as well. whether you want to spen the extra money though is completely up to you. I'm pesonally a huge believer in high performance graphics though.
if you havemore questions feel free to email me at [email protected]
Thanks for the quick responses!
I meant resolution
you can max counter strike with a 9800gt, even the 7870 is overkill. so out of those 2 i would say 7870. It maxes everything at 1080p. save your money unless your gaming at 2560 by 1440 or using 3 monitors
for counter strike, even a 9800GT would be overkill, i remember maxing it @1080P on a ATI Radeon X850 XT 256MB and getting 70+ FPS at all times
he may be speaking of the new counter strike?
