Radeon 5970 Need Help AGAIN!
I just recently got my radeon 5970 going again and when i play a game it crashes and says that the driver crashed and has recovered. Well I got that fixed and now when I play games it just throws lines all over my screen and the game and my computer freezes. I know that it is my gpu because i put my dual 6770's back into it and my games run amazingly. I just need to know if it has something to do with the gpu's in it and/or if i need to reflow it??
sell it to me so i can test it :$
Na I'm good I realy like my 5970 it was working fine before so no.
Run a temp gauge while you are trying to play a game. See if your temps spike. If they do, its crashing from overheating. Not exactly sure if I'm right, but it's still worth checking.
OK thanks I'll check it. I will inform you if that is not it.
Its not the temps they increase by like 4-7degrees when it crashes.
Have you tried reinstalling the drivers? Also are you using the latest support by that GPU?
Yes I have reinstalled the drivers and went back to older drivers and it doesn't fix the problem.
I have heard that some people are having the same problem as me and they said to under or overclock it. Some fourms say that it is unstable and over or under clocking it will fix that.
