Linux has been a tedious nightmare but I won’t give up on it. I’ve gone through several guides to try to get this to play anything and have failed.
So far most games straight up fail to render even 1 frame and freeze up and I have to ssh in to kill that game. Two games so far have made it beyond that to a stuttering ~20fps.
I’ve got Ubuntu 18.10 currently with amdgpu
active & radeon
blacklisted.
I was going to try to install the AMD supplied drivers for 18.04 (no 18.10 available yet) but now apt-get is stuck in a broken state and somehow even though the installers failed, they installed amdgpu-uninstall
& amdgpu-pro-uninstall
:~$ dmesg | grep amd
[ 0.000000] Linux version 4.18.0-16-generic (buildd@lcy01-amd64-022) (gcc version 8.2.0 (Ubuntu 8.2.0-7ubuntu1)) #17-Ubuntu SMP Fri Feb 8 00:06:57 UTC 2019 (Ubuntu 4.18.0-16.17-generic 4.18.20)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.18.0-16-generic root=UUID=fae7d5d0-6933-482b-95a3-905f616c96fe ro quiet splash radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1 amdgpu.dc=1 amdgpu.dpm=1 vt.handoff=1
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.18.0-16-generic root=UUID=fae7d5d0-6933-482b-95a3-905f616c96fe ro quiet splash radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1 amdgpu.dc=1 amdgpu.dpm=1 vt.handoff=1
[ 0.550876] pcie_mp2_amd: AMD(R) PCI-E MP2 Communication Driver Version: 1.0
[ 2.643633] [drm] amdgpu kernel modesetting enabled.
[ 2.658143] amdgpu 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.582320] amdgpu 0000:01:00.0: VRAM: 8192M 0x000000F400000000 - 0x000000F5FFFFFFFF (8192M used)
[ 3.582322] amdgpu 0000:01:00.0: GTT: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 3.582410] [drm] amdgpu: 8192M of VRAM memory ready
[ 3.582412] [drm] amdgpu: 8192M of GTT memory ready.
[ 3.805994] amdgpu 0000:01:00.0: fb1: amdgpudrmfb frame buffer device
[ 3.807632] [drm] Initialized amdgpu 3.26.0 20150101 for 0000:01:00.0 on minor 1
[ 4.211587] amdgpu: [powerplay]
:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following additional packages will be installed:
amdgpu-core
The following NEW packages will be installed:
amdgpu-core
0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
45 not fully installed or removed.
Need to get 0 B/2,348 B of archives.
After this operation, 12.3 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 file:/var/opt/amdgpu-pro-local ./ amdgpu-core 18.50-725072 [2,348 B]
(Reading database ... 310964 files and directories currently installed.)
Preparing to unpack .../amdgpu-core_18.50-725072_all.deb ...
ERROR: This package can only be installed on Ubuntu 18.04.
dpkg: error processing archive /var/opt/amdgpu-pro-local/./amdgpu-core_18.50-725072_all.deb (--unpack):
new amdgpu-core package pre-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
:~$ sudo apt-get purge amdgpu-core
Package 'amdgpu-core' is not installed, so not removed
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
amdgpu-dkms : Depends: amdgpu-core but it is not going to be installed
amdgpu-lib : Depends: amdgpu-core (= 18.50-725072) but it is not going to be installed
glamor-amdgpu : Depends: amdgpu-core but it is not going to be installed
gst-omx-amdgpu : Depends: amdgpu-core but it is not going to be installed
libdrm-amdgpu-common : Depends: amdgpu-core but it is not going to be installed
libdrm2-amdgpu : Depends: amdgpu-core but it is not going to be installed
libdrm2-amdgpu:i386 : Depends: amdgpu-core:i386
libegl1-amdgpu-mesa : Depends: amdgpu-core but it is not going to be installed
libegl1-amdgpu-mesa:i386 : Depends: amdgpu-core:i386
libgbm1-amdgpu : Depends: amdgpu-core but it is not going to be installed
libgbm1-amdgpu:i386 : Depends: amdgpu-core:i386
libgl1-amdgpu-mesa-dri : Depends: amdgpu-core but it is not going to be installed
libgl1-amdgpu-mesa-dri:i386 : Depends: amdgpu-core:i386
libglapi-amdgpu-mesa : Depends: amdgpu-core but it is not going to be installed
libglapi-amdgpu-mesa:i386 : Depends: amdgpu-core:i386
libllvm7.0-amdgpu : Depends: amdgpu-core but it is not going to be installed
libllvm7.0-amdgpu:i386 : Depends: amdgpu-core:i386
libwayland-amdgpu-client0 : Depends: amdgpu-core but it is not going to be installed
libwayland-amdgpu-client0:i386 : Depends: amdgpu-core:i386
libwayland-amdgpu-egl1 : Depends: amdgpu-core but it is not going to be installed
libwayland-amdgpu-egl1:i386 : Depends: amdgpu-core:i386
libwayland-amdgpu-server0 : Depends: amdgpu-core but it is not going to be installed
libwayland-amdgpu-server0:i386 : Depends: amdgpu-core:i386
mesa-amdgpu-va-drivers : Depends: amdgpu-core but it is not going to be installed
mesa-amdgpu-va-drivers:i386 : Depends: amdgpu-core:i386
mesa-amdgpu-vdpau-drivers : Depends: amdgpu-core but it is not going to be installed
mesa-amdgpu-vdpau-drivers:i386 : Depends: amdgpu-core:i386
xserver-xorg-amdgpu-video-amdgpu : Depends: amdgpu-core but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Is it even possible to game on Linux with this card?
