R9 290x Sapphier Tri-x Sgminer Setings
r9 290x Sapphier Tri-x
So Now Finally i Found Some Good settings for my 2 sapphire cards. I have been playing around with them for 2 days now
I'm getting about 960 Kh/s Out of them.. I can go To about 1000 kh/s  but then the valid shares go Way down, To about 97%.  At 960 i'm at 99,8 % valid That can be the internet connection to the pool bad
strangely the best settings for my for my 2 cards was exactly the same so others may get the same numbers as me
I use sgminer 4.1  and Catalyst version 13.12
This is the config raw paste
"pools" : [
                        "url" : "stratum+tcp://euro1.coinhuntr.com:3333",
                        "user" : "Ctheg.1",
                        "pass" : "x"
"intensity" : "21,21",
"xintensity" : "0,0",
"rawintensity" : "0,0",
"worksize" : "256,256",
"kernel" : "scrypt,scrypt",
"lookup-gap" : "2,2",
"thread-concurrency" : "32765,32765",
"shaders" : "0,0",
"gpu-threads" : "1,1",
"gpu-engine" : "1020-1020,1020-1020",
"gpu-fan" : "auto,auto",
"gpu-memclock" : "1500,1500",
"gpu-memdiff" : "0,0",
"gpu-powertune" : "10,10",
"gpu-vddc" : "0.000,0.000",
"temp-cutoff" : "95,95",
"temp-overheat" : "89,89",
"temp-target" : "85,85",
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "1",
"failover-switch-delay" : "60",
"gpu-dyninterval" : "7",
"gpu-platform" : "0",
"log" : "5",
"no-pool-disable" : true,
"queue" : "1",
"scan-time" : "1",
"tcp-keepalive" : "30",
"temp-hysteresis" : "3",
"shares" : "0",
"kernel-path" : "/usr/local/bin"
 If u want to try for 1000Kh/s  U can increase the intensety to 23. And the gpu-powertune to aboute 20  That’s wher I got it to be stable but the invalid shairs was To hige so im sticking whit 960 kh/s
Iff u feel like it u can donaite som Litecoins Or Anoncoin To me
LTC : LLKrfmWMkJ7ZsetNjpb4pEJFquJ5iwNH3v
ANC: AYdBTNZdXv7jNqfG5R5rnVT2e1FKDwAf5S
I am using CGminer with a 290x as well, but I am getting 981Kh/s plus or minus 2 Kh/s. Post #1729 has my settings. http://www.overclock.net/t/1437876/290-and-290x-litecoin-mining-performance/1720#post_21663603
Why don't you use CGminer?
