R9 290 Vs GTX 780
Ive heard alot on news on the r9 290 NOT the 290x just the 290 going to have better coolers now which their prices are just as much as the 780 so which is better for gaming?? And video editing in adobe premier?
The 290 no doubt, but I'm sure the 780 Classified would give it the run for it's money. Remember, aftermarket 290xs are being compared the reference 780s (or similarly spec'ed aftermarket ones, clearly the K|NGP|N card will be the number one card for awhile, but it's still worth noting, especially with the pricings).
Now with video editing and adobe stuff, it's all about compatibility. If there is OpenCL, the 290 will without a doubt eat the 780 alive... The 290 has 4848.64 gflops while the 780 only has 3977. Alongside the driver limitations Nvidia does to promote their pro-grade cards (by limiting FP64 units at only 12.5% of the core clock), it ends up in the dust (AMD does do something similar, but not nearly as throttling). The only case where the 780 would shine is if CUDA is the only supported architecture. It would also hold it's own in an optimized environment (something that could make up the flops difference).
