R9 290 or R9 280x
Hey guys,
So I'm looking to upgrade my video card, and at the moment I'm running a dual monitor setup both 1920 x 1080 monitors. I am trying to decide between a:
   - Gigabyte R9 280x 3GB OC for $317AUD
or
   - Gigabyte R9 290 4GB for $389AUD
I am looking to get another monitor which is 2560 x 1080, I want to run all three of them but only game on the 2560 x 1080 monitor, the rest of the time it will be used for web design and Photoshop work.
So any recommendation would be great.
Thanks for your help.
I'd recommend the 290. With a set up like that your gonna want all the power you can and the 290 isn't significantly more. Just be sure it doesn't have a reference cooler on it.
Ok thanks, and thinking about it for $70 more its probably the better value as well.
I probably would buy a r9 285 (true audio and mantle)
290 all the way , the 4gb are amazing for high res
Mantle runs like trash on the 285 at least right now.
I would use the $70 to buy games :P
290 No brainer.
its not even close.
