R9 280x Toxic Drooping
I just installed my 280x and i put my case upright and i noticed that at the back of the card it was drooping, i just wanted to know if anyone else is experiencing this and how i might fix it or thats just normal?
Thanks
It's normal, even with a backplate it's expected.
If you think about it, there's this big card and all it has for support is the back-panel (only supports the back) and the PCI-E port (not much support there).
is it a potential danger to other components and or itself? :/ just wouldnt like my €300 card to break :p
