So i was wondering if its possible to crossfire the R9 280X and the R9 290 or R9 290X?
No the cards must be the same series you can cross fire them with their 7000 series equal though.
No that's incorrect, you CAN crossfire those cards but they will only run at the speed of the slower card.
Not even a little.
280x is a 7970. It requires a crossfire bridge for crossfire. The 290s have no crossfire bridge or even a connector for one.
I think you can because it can be done threw the Pci-e slot with the software update. I believe that will work with any card that has the newest software, I think it was just a software thing because Pci-e has the bandwidth. Maybe there is also a hardware thing on just the 290's to use Pci-e but i don't think there is...
nope, besides you can't crossfire cards with different cores, the software will not even let you try to crossfire a tahiti chip and a hawaii chip
I'm sorry but you won't be able to do that. You can CF a r9 280x with a 7970/ghz but other than that won' be posible. as it has been said before, it won't even let you try.
Thanks for all the answers, it was very helpful
