It really depends on what you're doing it for. I maybe wrong, and someone will scream at me if I am, but if you are gaming at 1080p, the 4670k and 7950 would be fine. If you were planning on doing streaming said games and/or video editting, grab the 4770k. If you were planning on using a 120/144 Hz monitor, really push the most out of the latest games, and/or game at 2560x1440, grab the 280x.
i would personaly go for the i7 if and the 7950 if your pc is an allrounder, reason, because the 7950 is still a very capable card, its not far behind the R9-280X especialy if you overclock the card. i would play arround with that 7950 because it will still last you for a while. the price diffrence between the 7950 and R9-280X at the moment (because of mining), is not worth the performance diffrence between those 2 cards at the moment.
I would play with it, till the R9-290 non reference models are on the market, then i would sell the 7950 (litecoin miners love them), and buy one of those R9-290 non reference sweety´s. and be the king of the ring
While it is true that the 7950 is only a fraction behind the 280x after overclocking, I wouldn't get the i7 for the sake of getting an i7. Particularly if you're only gaming or doing light editing work. There is the larger question "do you really need an i7?".
It might be advisable to grab an i5 and a 7950. That way you save some money. Could grab an SSD, as many SSDs are now reduced in price.
I thought I would revisit this post because I didn't say it all in the beginning. And I do have to agree with some other points/alternatives raised.
I5 with the R280x. The added bonus of the i7 4770K is so little compared to the GPU power gain.
For instance the whole overclocking thing. Both cpu's go just as far. The 4 Hyperthreading threads are not much used for gaming. A little bit more in a few programs like Premiere and Photoshop but in the end you have more gain of a 280x than the cpu.
Also mining on a gpu is stupid. If you jump into that wagon now you are too late.
Definitely, FX 8350 is so good for the money. And when mantle is implemented it's amazing for gaming as well :D Btw can someone please have a look at my thread :( "New Here - Building a PC"
Depends mostly on what programs he plans on using in terms of productivity.
If it's light/medium Photoshop work and little video work or 3D work I would hands down pick an I5 over the FX.
If he really does make heavy use of Photoshop, 3D Max, Solidworks, Premiere, Blender or Avisynth and such the FX8350 would be better.
Productivity is a broad concept and the OP could have mentioned what he uses, because for using Word, Excel and basically the majority of programs that gets used hardly utilizes the 8 cores of the FX
