Quirky behaviour with the Steam Deck Dock Display Port port and KVM
KVM Model:
1.4 Display Port KVM Switch - Single Monitor - Four Computer
10-gigabit
Problem:
Steam Deck works funny.
In the “Normal/Gamescope mode” of Steam Deck:
  • Attaching the Display Port 1.4 → flickers/doesn’t work.
    • Pressing Ctrl+Alt+F4 goes to Terminal 4 properly but cannot rerender the default “F1” terminal
  • Attaching a Club 3D HDMI Input to Display Port Output converter → KVM works normally
In the “KDE Desktop mode”":
  • Triggering Big Picture Mode on Desktop Mode Steam just after attaching the cable “fixes” the Display
  • I cannot return to a working Steam Deck Normal/Gamescope mode after switching to other machines.
Does the official Valve Steam Deck Dock adhere to proper DP 1.4?
@wendell do you have any insight?
Do the other PCs via DP 1.4 work fine?
Yes its just the Steam Deck Dock. I have a Moshi USB-C to DP 1.4 and it doesn’t seem to work directly on the Steam Deck, at least right now either in normal mode or desktop mode though I swear I remember it used to work.
Hmmmmm… does a power cycle affect anything?
It did not.
