It can work but I have concerns of the longevity. keep in midn that most videocard fans have no guards, if the glue ever weakens and it comehow vomes loose (the fan does vibrate a lot), it will drop down and you will have 3000+ RPM of spinning plastic hitting delicate components in the system.
A far safer solution is to simply add sound dampening foam to the case. (it not only blocks sound directly, it also stops conducted sound as panels with the foam attached, will be less likely to vibrate)
certain cards cannot be passively cooled, for example, a 170-250watt TDP component requires active cooling if you want the component to fit inside of a case. Furthermore, high TDP videocards, depend on direct airflow across the VRM heatsink, and even then the VRM's will run at nearly 100C
Most of the passive coolers sold on sites like newegg and amazon, will have a rating of 40 - 60watt TDP or less, and require good case airflow, and the higher 150 watt limits are listed with optional fan.
The fans in the gainward cards are ment to run very quietly so it is quieter than a normal card. But something like a DC2 card will be very close and cooler better.
