Quiet Fans
I currently have several 120mm Cooler Master fans on my system with the following specs:
Noise: 19 dBA
Air Flow: 70 CFM
They work very well, but are loud since I have so many of them.  Does anyone out there know of any fans that are quieter without loosing too much airflow?
What's their purpose? Case fans, heatsink fans, radiator fans?
Either way, Linus, from Linus tech tips, uses Noctua NF-F12s for everything, and they are SILENT! I'm going for those next if my new case isn't quiet. They are expensive but I'm sure they are worth it.
I have the stock Hyper 212 evo fan and it is pretty much quiet, if not silent. Even at full load it isn't very loud at all. Maybe I just got lucky and got a really good fan. Otherwise, I'd say look at that one as well.
http://pcpartpicker.com/part/noctua-case-fan-nfs12apwm
Noctua airflow case fan. You can get non pwm options. Ugly but great performance.
They are mostly case fans, 4 as a side intake (there is a stock 240mm fan that came with my Cooler Master HAF 932 Advanced case as a front intake), and 1 rear exhaust.  I also used 2 to replace the fans on my Thermatake Water 2.0 Extreme CPU cooler because at the time I believed they were quieter than the stock.  I didn't feel comfortable running 4 fans off a single motherboard fan connector, so I plugged the side fans directly into the power supply, so that makes them louder still.
You can get 'low noise adapters' to convert the 12v power to 5v or 3v (3v probably silly), but you obviously get less performance. As far as running fans off a single header try something like this: http://www.pccasegear.com/index.php?main_page=product_info&products_id=17923&cPath=73
Gives your pwm fans power from your PSU diorectly but still gets the speed signal from your motherboard so you can controll their speed with software.
Thanks, this could be exactly what I was looking for, regardless of whether I change the fans or not.
