Quiet fans on a budget
I would love to be able to spend $30 on fans but on my budget I can't. If you guys could name a few cheap quiet fans that would be great.
For your case or radiators/heatsinks?
Both
Cougar Vortexs; good CFM and stiaitc pressure for both case fan use and radiator use.
Generally, the fans you use for a radiater are different than what you use for the case.
4 pin pwm for the rad . 70 cfm to 119 cfm  3 pin pwm 60 cfm to 102 cfm for the case. they are very nice  fans for the price
I'll keep that in mind
