And what will hold it together ? friction ?adhesion ? also you need to remove all the labels to get some heat transfers. To put heatsinks in place usually means using thermal glue, but try to rma your drive then.
Don't the thermal pads already have some sort of adhesive?
In any case here would be the other option, something like these
