Quiet CPU coolers and case fans?
Looking for a CPU cooler in the 17Db - 22Db that's not super expensive, also looking for case fans in the same range. Thanks in advance.
in that range of silentness your probably looking for noctua nf or corsair af series of fans but they are not cheap, or you can buy cheap fans with fan speed reducers to be silent but your sacrificing the performance (btw dont buy pwm fans they make weird noise when their on fan speed reducer) with the cpu cooler depending on you clock you can buy like coolermaster evo and run the fans with fan speed reducer if you plan to overclock spend a little more on you cpu cooler you will be much happier
yea the cooler master hyper 212 evo is quite i have it but also this  http://www.newegg.com/Product/Product.aspx?Item=N82E16811352020 great for nosie REDUCTION
If your case can handle 200mm size fans they are almost silent because they can move so much air with less RPM. I have 3, 200mm Cooler Master Blue LED fans in my case and I honestly cannot hear them. Of course I’m getting older too so the hearing is not what it use to be!
well what is you CPU, your case, and is it overclocked?
