Quickfire TK vs Blackwidow ultimate 2013
Currently deciding on either the CM Storm Quickfire TK vs the Razer Blackwidow Ultimate 2013 Edition.
The TK is cheaper by £30, but I am wondering whether or not its worth paying £30 more for a full size keyboard -the blackwidow - as I find having full sized keyboards easier, and I have the desk space so there's no need to go for compact. I think I'm near certain on my decision for going with the blackwidow, but I have one other variable effecting my decision; the key switches.
The blackwidow only comes with Blues as far as I know, so if I decided to go with red/browns, my decision is made for me. I have used Cherry MX Reds before, and I thought they were all right, but I think I prefer a bump/click in my keys, so I am wondering whether the blue switches are good for gaming.
If blues are good/comfortable I will probably go with the blackwidow (unless there is strong advice against it). If not I will buy the TK, and just get used to not having dedicated home/end keys etc.
Blackwidow is the only mechanical keyboard that I don't recommend.
I have the Quickfire with blues in it and I love it, I moved from a full size to it and after about a day you get used to it. You basically just have to toggle Numlock on and off if you want to use the home key etc. but it's not that big of a burden at least to me.
I have a CMStorm Trigger (Cooler Master's full sized gaming keyboard) and I love it. Though I would choose some other switch than black (it doesn't seem as responsive while typing, but gaming is great).
Thanks for your replies. Unless you can give some factual unbiased reason against the Blackwidow I don't see why I should listen.
Yes I think I would get used to it, but I'd rather stick with full size if I can help it.
Blackwidow has wobbly stabilizers. One Tek member made a video where he could press left shift the way it blocked A from releasing. Well, it's Razer, what did you expect? I wouldn't count on it being reliable. It also doesn't have PS/2 support.
