Quick question
Ok, so here is a quick question:
Is 600w psu enough for R9 280X and a cpu with TDP of 95w?
I just need to know will it work or will it explode.
Thanks.
yes.i hope it's atleast bronze rated.
Thanks for the answer and yes its bronze rated. But why is the recommended psu 750w if it works on 600w psu?
maybe they are accounting for non bronzed rated psu (less efficient)
because you couldn't possibly find parts that use that much so there's no way someone can complain that their power supply isn't big enough
