I like the aesthetics, but somebody on another forum has told me that it is pretty small, and there are other cases I'd be better off getting.
Can you tell me what you think?
Also, could you let me know any other cases for under £55 from Amazon.co.uk or Dabs. I would like a sort of sleek black design, Leds in the front are cool but I'd prefer not. Although, if this is all you can find, I'd love to take a look at it too.
To be completely honest, I've been searching for a new case for about two months. There are a LOT of cases out there, with very different style, price ranges, and features. It helps reading many, many reviews and watching youtube videos.
I feel that picking a case is very personal, and it depends on the looks you prefer, your budget and the features you think will be most useful to you. I am also a ferm believer that you will keep a good chassis longer than one or two hardware update cycles (same goes for the PSU and the peripherals).
My personal opinion is that the Carbide 200r is a good case for that price.
Now, if you are looking for better cooling support (including stellar watercooling), removable hard drive cages or simply better fan filters you can always buy the Fractal Design Arc Midi R2, it's about 75 pounds on amazon.co.uk.
If you are looking for a silent case, an understated design and great quality, you can take a look at the Fractal Design Define R4 or the Nanoxia Deep Silence 2 cases (both around the 75 mark).
