I have a X399 Designaire. There’s a two segment led display for error codes. Can I test this unit for a good post without a monitor (but with a video card) using post codes on that leg segment display?
Yeah if it boots without a monitor it will usually go to a all good (at least asus did that like AA or something) Check the user manual for what gigabyte uses
Looks like “AD Issue Ready to Boot Event for OS Boot”, pg 113.
Thanks for your help.
NP GL
