Is the G.SKILL SNIPER F3-12800CL9Q-16GBSR1 RAM going to work perfectly on my P9X79 LE MB
or will there be any compatibility issue?
Thanks in advance
Thanks in advance
Hi Liranmn, this RAM will work as the memory is unbuffered and the error checking is non-ECC. Also the motherboard supports the frequency of the RAM. This is the information i have gathered from two manufacturers websites. Danny
