Quick PSU question
If I have a Corsair TX-850 PSU will it support 2 GTX 780s and my overclocked 8350?
If i bought another of the EVGA 780 I currently have which only draws about 230 watts at full load (assuming they'd have similar power draw)
Would the 390 leftover watts be enough to power:
AMD [email protected] (1.493 vcore)
Asus M5a99x Evo R2.0
1 ssd
1 hdd
3 140mm fans
and an h100?
yes no problem
850W is more then enough. this setup will maybe draw arround 650 to 700 watts max, on full load.
only the TX is a 80+bronze psu, so it will be a bit less efficient for your powerbill, then a Gold rated psu. But i would not botter to much about that.
