Currently looking into getting a new hard drive due to some messing around that I needed to do that involved putting in and taking out a hard drive about twice in the past.
I wanted to ask if it would be possible to get a plastic 3.5 inch removable drive bay that I can install my hard drive into and just slide it into place rather than messing with screws and the interior mounting bracket which I need to remove in order to screw in a drive, something similar to this:
I had a quick look on amazon and all I could find was brackets for mounting 3.5 inch into a disk drive slot and a 2.5 inch to 3.5 inch bay.
Any help is greatly appreciated.
Hellome118
Edit: My case is a Cooler Master Elite 311.
