Quick Compatibility Check
Hey guys, just wondering if these parts will work well with each other, thanks in advance
http://www.buy.com/prod/gigabyte-ultra-durable-3-classic-ga-990fxa-ud3-desktop-motherboard-amd/221978211.html?listingId=-1
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130683
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
why u gettin a 560 just get a radeon 7870 or if you have enough a 7970
Im totally with 'that kid' Unless you have money to buy 680 or 690 just dont buy Nvidia just go for amd!
And yes they're compatible :)
and if ur not going to overclock theres no need to get that cpu :get a fx 6300 or the 4000 one (dunno the exact name) but if u are overclocking get the same cpu as u picked
ok thanks
