I’m looking at buying a Dell XPS 13 for school to run Fedora. The XPS 13 has fairly limited IO with only one USB-C port and 2 USB-A 3.0 ports. I think I will also get a 4k monitor for this (recommendations?). I tried to find a hub with
- 1 displayport (preferably mini)
- 1 gigabit ethernet
- more USB 3
I had thought that USB-C was capable of transmitting both a displayport stream and a usb 3 stream. But the only hub I could find was this plugable usb-c to dual 4k displayport and gigabit lan. However it has some major problems.
It appears to not be compatible with Linux.
It operates solely on the USB 3 bus, and having a 4k60hz signal plus gigabit lan on the same 5-gigabit bus is extremely problematic at best. Not to mention it not even being on the Intel iGPU.
So, unless anyone can find a better option I am just thinking I will get a 4k60hz compatible USB-C to mDP adapter.
Now about the Dell XPS 13. I’m planning on getting this laptop on a deal from costco for $1300 once their black friday sales go live, so I have a pretty good deal lined up.
I have some questions and concerns about this.
The touchpad. I know that the touchpad is great under windows precision drivers, but is it as good under Linux?
Wifi card. I would be buying the non-developer edition, so I believe that means I would be getting a Broadcom chip. Should I just replace it.
DPI with Gnome. It is really as bad as everyone makes it seem? I can live with some items small.
Dual booting. This isn’t really a concern, but I have a few questions. Is GRUB good to go with NVMe drives now? Also, is there an easy way to add an option in Gnome to restart into Windows?
Touchscreen. Is it good for Linux and Gnome, and is there a way to hot-disable it easily?
