How does it perform in gaming? I know xeons especially when you have two of them aren't really optimized for gaming, but can you get away with it with some decent performance? I know it's supposed to be a workstation but can you enjoy some skyrim on the side?
What programs do you guys use this for? What types of programs utilize all the power from this certain setup?
How loud is it?
In what situations would you get a Quadro over a GEforce card? What are the advantages of Quadro over GEforce? What's the difference between Quadro and Firepro? Do different programs utilize them better than the other?
How bad would it beat the new mac pro?
What games was pistol playing in the background?
i know it's alot but I would appreciate if someone answered at least a couple. Thanks!
1. It will do for gaming, but if gaming's what you do more of, it'd be best to swap the Xeons and mobo out with the consumer line.
2. Audio editing, video editing, photography, 3D, you could do a lot with it. Wendel stated that this particular build was for a specific application that made use of a special feature of the Xeon, but otherwise it's a well-rounded build (for work).
3. It's in a FD R4, which is an extremely quiet case. Coupled with the Noctua CPU cooler, even better. If the GPU is anything like the 780s I toyed with a few days ago, then you won't hear it until you hit extremely high load (as expected...).
4. As rabidz7 said, the Quadro and Geforce lines seem to be the same or similar cards with different firmware (although making a Geforce card into a Quadro isn't as easy as it seems. Check here). I think it's the same with Radeon/Firepro. It's likely that there are modifications (both on the hardware and in the software) to improve either line's performance in their intended task.
As for programs utilizing them better, yes; in some cases, Nvidia's cards will outperform AMD's and vice versa. I believe Nvidia cards run better for the Adobe suite, but mostly because Adobe and Nvidia have had a long-standing relationship and a lot of time to develop their software together (note that the difference here is probably a lot smaller now). On the other side of the coin, AMD cards can (for example) mine *coins a lot better than Nvidia cards because they have instructions that come in really handy for SHA-256.
5. Speaking entirely theoretically, I'd imagine this build would win in a multhreaded scenario but lose in a single-threaded one; this has more cores and threads but slower clock speed. If the Mac Pro happened to come with the E5-2697 (for an extra $3000...) then it wins. GPU-wise, I'd imagine the Pro would win. All that said, I've never touched any systems like these and I haven't done much research; my thoughts are mostly from the few minutes of Googling I did.
