I was looking at gpus and a got reminded about Nvidia Gamestream, and I was wondering if you can use the computer handling the game for things like internet browsing and other light tasks while the game is being streamed to a shield. Thanks in Advance!
No. Whilst Streaming to the shield the computer screen must show the game playing, you CANNOT multi-task on your desktop while using Nvidia Game-stream. also taking into consideration your computer must have a Kepler based or Maxwell Based GPU to use Game-stream if you aren't already aware.
Ok, can i have my monitor turned off while streaming?
yes.
Thanks ill likely go for Nvidia then
