Hi, so in short, I’m unsure on how to go about using a physical SSD I have (not mounted, previous windows install on it) in my VM. Tried to search but my google fu was not strong.
Also is it better to use a .raw image stored on an ssd or just use the ssd itself? not sure how it works. Thanks for any input!
You’re correct, I don’t think it recognizes the TRIM. I couldn’t find a way to balance TRIM and being able to boot into it natively, all the things I could find about keeping TRIM called for a qcow2 image and using virtio-scsi. I think you can add discard=‘unmap’ to the driver line but I’m not entirely sure if that will cover it, I’d have to try it out.
