I have a Gigabyte Aorus Master X570 and would like to flash the newest BIOS using Q-Flash Plus. The manual states I should uncompress the downloaded file and rename the extracted one to GIGABYTE.BIN.
However, extraction results in 4 files:
autoexec.bat
Efiflash.exe
readme.txt
X570AOMA.31e
Am I supposed to rename X570AOMA.31e to GIGABYTE.BIN or am I supposed to rename the whole zip file? Does anybody know?
Edit 1: The post below seems to suggest to rename the X570AOMA.31e file.
Edit 2: According to the guy in the video below, it’s also the former:
Note: correct file you’re renaming but note that .bin is lowercase.
You’re using Q Flash because you have bought a 5000 series Ryzen and the board wasn’t already flashed to work with it?
(Just double checking - because I have heard people going through the bios update using qflash when they have a working cpu and could just update straight from the bios…)
I have just finished installing my Ryzen 7 5800X and had the same problem with a new B550 AORUS Pro board.
So basically you only need one file which is in you case X570AOMA.31e. You have to rename it to GIGABYTE.BIN and put in on an formated empty FAT32 thumb stick. You plug in the thumb in the USB and press the button. It takes about 5 minutes and shoul be ok.
Yeah, just rename the .31e file to GIGABYTE.bin and put it on the root of a FAT32 formatted USB stick. Since it’s a hardware level solution, make sure the stick is MBR instead of GPT. Most unmodified FAT32 USB sticks should be MBR if it’s 16GB and below.
