Question : MB chipset
for me to run a AMD FX X6 6350 ... do i REALLY need a MB with AMD 990FX Chipset ???
will a AMD 760G + SB710 Chipset do ?
i will not do overclocking on this rig.
this is the MB i kind of want to use : https://www.asus.com/Motherboards/M5A78LM_LX3/#support , it seems the  AMD FX X6 6350 is supported by that particular board... but , will it run as it should ?
Its supported and it will run but, you really want a motherboard with a better power delivery system. The 6350 draws the same watts as an 8 core fx 8350. I'd use a 6300 on that board. It draws 95 watts instead of the 125 on the 8 core and 6350. Plus the performance difference between the 6350 and 6300 is unnoticeable :)
it does not run out of the box you need a bios update.
Unless the manufacturer allready did a bios update.
yeah... i think i might need a BIOS update... so i might want to buy this one : http://www.msi.com/product/mb/990FXA-GD65.html#/?div=Basic better components and more features for me to use in the feature.... right ?
