Hi so he was just wondering if this build http://austinnotduncan.com/builds/boson/ is any good here are the questions
1. Is it good and will it be able to play things like DayZ at any settings and Arma 3 at any settings
2.is their any improvements that could be mad to it that keep the cost at 250£
3.if not then is thair any better builds for 250£
thanks in advance to any one who can help (^_^)
-Alex
-RandomCow909(っ◕‿◕)っ
THANKS GUYS!!!
Ratzzz
3
D) Friend doesn't have a computer. lol
e) he doesn't have a computer and thus has to use an xbox so he cant type so i asked for him as it was faster
I would get this for OCUK :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-169-PC
http://www.overclockers.co.uk/showproduct.php?prodid=CP-377-AM
http://www.overclockers.co.uk/showproduct.php?prodid=HD-252-SE
http://www.overclockers.co.uk/showproduct.php?prodid=CA-154-BX
http://www.overclockers.co.uk/showproduct.php?prodid=CA-059-CS
http://www.overclockers.co.uk/showproduct.php?prodid=MY-023-TG
http://www.overclockers.co.uk/showproduct.php?prodid=MB-484-GI
Better looking and MUTCH better performing .
If he can't spare the extra 47 pounds , the downgrade the gpu to a r7 260x
http://www.overclockers.co.uk/showproduct.php?prodid=GX-228-MS
That case in Austin's build is ugly... :(
(Personal preference though... I can't fault him for saving $$$ on a $300 build)
I don't think his build would run DayZ or Arma 3 at max, but should do a decent job. (I could be wrong though)
Yes it is ugly :/
But my build has a better looking case :p
