Question for Logan
Hey Logan I have a couple questions for you. First off how do you get separate wallpapers for your desktop? I have found some programs online I just want to be sure they are legit before I go downloading crap.
When is the video tour of the secret forest house coming out? I would really like to see it!
Splice two wallpapers together using paint or something similar, then set that as the background. You will probably have to change the stretch/zoom/tile setting to get what you want.I think tile works but the resolutions will have to be exact.
Either what deathright said or get displayfusion. I bought it, works like a champ.
Also windows8 includes a multi monitor wallpaper function by default (finally). That's what Logan does, I believe, just stock windows 8 on a slideshow.
cool thanks
Ok I have a question I have been looking for a program "list of names and dates" that multiple users can use and edit at the same time.
I use this http://dualmonitortool.sourceforge.net/dualwallpaper.html it's great! I have a 50" 1080p and 19" 1024p and they both display ad per normal with separate different sized pics :)
