Question for Inbox.exe
Hello, Neediness here.
 I recently got an equalizer software that really helped with "fixing" the audio of one of my headphones. I think it would be awesome if Logan could make a video talking about equalizing and what you can and can't do with it, and also his own preferences with regards to equalizing.
 Much love!
That may depend on your drivers. I'm not running any sound drivers so the only thing I can really change is the volume.
I'm not sure which version of Windows you're running, but on 8.1, that doesn't work and if I'm following the windows settings paths correctly, the "levels" tab in a audio source/recording source is just volume adjustments.
I'm sure OP is talking about an EQ like what you'd use in foobar2000 to tweak the audio taste or to compensate for lack of sound in highs mids and lows
