QUESTION: Bandwidth on SlimSAS
Hey Gang,
Question - what kind of bandwidth can you get on SlimSAS on the SuperMicro H12SSL-NT MOBO using the SuperMicro CBL-SAST-0827 cables?
Looking to build some media storage to eventually phase out our Promise Pegasus32 R8 units with TrueNas-based system.
Thanks!
PCIe Gen4 with Rome or Milan EPYCs.
Getting “good” cables on the other hand has been the Bane of my DIY home server existence for over a year now (still unsuccessful, I don’t consider connected devices to just run with PCIe Gen4 a success, I don’t want any PCIe Bus Errors) - for more details refer to this thread:
I think you are living on another planet @aBav.Normie-Pleb cause I can’t for the life of me figure out how that has anthing to do with my question? LOL :innocent:
Oh sorry, I didn’t even think of not using the ports for PCIe!
You can get around 560-570 MB/s (that’s the best I’ve ever seen with Samsung 860 PRO SATA SSDs) per drive port with the fastest SATA SSDs :stuck_out_tongue:
Since every connection goes directly into EPYC’s SoC you don’t have any chipset interface bottlenecks.
Ok, I know the bandwidth of the SSD devices - but the question is the SlimSAS bandwidth via the cable my friend!
These ports don’t come from a SAS controller, you can only choose between SATA/AHCI and PCIe/NVMe.
It’s only the physical connector on the motherboard end that is called “SlimSAS”.*
When using them for SATA 3 just multiply the number of drive ports with 6 Gb/s.
*There sometimes are motherboard variants that have a proper SAS controller chip onboard as an additional feature, but not the model you’ve refered to.
So you know that 8 drives on this cable will support 8x6Gbs or you are speculating?
That’s the whole point of these break-out cables, yes. With SlimSAS 4i you can use 4 drives individually, with Slim SAS 8i you can use 8.
