Question about sound cards
I recently bought a pair of JVC HARX300 Headphones and I noticed that they're not as loud on my computer as they are on my friends' S3. I don't have a seperate sound card and I'm thinking of buying one. So my question : Should I stick to a cheaper solution or go mid-range for my sound card?
I don't see why they wouldn't be since the impedance is only 32 Ohm, meaning everything should be able to run it well. I would check your sound settings first.
If you're on a budget you could check out either the FiiO E11, FiiO E17 or the Audio Engine D1 24-bit DAC as an external device which works as an amplifier and sound card. Another plus is that you can take them with you as well if you have a laptop for example.
If you really want a sound card I would have a look at either Creative or Asus products, as they have released some new products recently, and I think the price for them are about the same or a bit more than what I have recommended. Sound wise I can't say, but either way, all of the products here should be more than enough for you.
Thanks. I've looked into some products and, correct me if I'm wrong, I should get an amplifier for the headphones to be louder ? It's really strange because the differience between my motherboards' sound and the sound that I get from an s3 is rather noticable... Would I get louder sound with a sound card at all ?
Edit: Could it be from my motherboard ? My computer is quite old - it's from 2008 and my motherboard is a Gigabyte P31-ES3G
A sound card is a dac and amp soldered onto one PCB, so it all comes down to how good the amp is on the sound card really. So to make your headphones louder an amp would get you sorted, and you can get that from the products I posted or any sound card.
So there are plenty of good choices out there!
