I'm building a gaming pc on a budget and this is the motherboard I have:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130679&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I'm looking to get 8gb of fast ram purely for gaming. I don't know if all ram is created equal or what type I need to get with this board, I'm assuming DDR3?
Can anyone help give me some options on what type of ram to get? I know newegg has sales a lot on ram.
Thanks
you need DDR3 ram indeed, 1600 or 1866mhz is fast enough.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
MisteryAngel,
Of these two links you posted for Ram which is better than the other? What makes it better? Or will they both do the same thing?
