Hi,
I have a Radeon Instinct MI60 that I use for GPU compute. I have recently been trying to use it in a passthrough setup, without success. I did some searching and encountered the often referred to Navi reset bug, and I believe that it affects this model of GPU (which is a Vega 20 if I’m not mistaken). However, I’ve had difficulty finding an explanation of what exactly the bug is, and what it means you can / can’t do exactly (especially an explanation aimed at someone like me who doesn’t know much about the details of PCIe)
Does the navi reset bug make GPU passthrough impossible with the affected devices, or is it just that once they’ve been passed through once, the host needs to be rebooted if the VM is rebooted?
Thanks, and sorry for re-treading what is familiar ground to many…
