Question about my build
First here my buld :
So ive noticed that my mobo doesnt support my ddr3 2133 ram and it only supports up to ddr3 1866 ram but theres no incompatibility error on pcpartpicker
so i was wondering if it maters and if it does can i get a mobo that supports it and everything else in my build
but is around the same price i have a budget of £550
Any help is appreciated
im not sure buy I bet you can look around for something about underclocking your ram for lower latencies and higher speed for it to be compatable. I'm probably wrong though :)
ok thanks
Plzz anyone i need help
