Hey guys, I'm new to the pc world and recently started my first build (still waiting on the case and psu to come in). I've figured out a lot of what I need to know on my own, but I had a question about fans. I'm planning to run all my fans directly from the mobo, as there are plenty of fan headers, but I was wondering even with doing that, will I have to get a variable speed fan to use different speeds? Or could I take a 2000rpm fan and somehow get it to spin at, say, 1200rpm?
The best thing is if your motherboard has pwm fan headers (4-pin as opposed to 3-pin) you can get pwm fans and your motherboard will know the rpms. Otherwise I think it just switches up the voltage to get them to run faster or slower.
HighlyIndignant is sort of right. The only issue is that most motherboards only have one or two PWM headers. Even though they might have more 4-pin headers this doesn't mean that they're PWM. The issue with this is that if you use a PWM fan on a non-PWM header it will either not allow you to control it all and it will just run at full speed, or it will actually damage it and cause it to fail in a short period of time. Just make sure that if you're using a PWM fan that you use it with an actual PWM header. These are usually just the CPU fan header and the CPU-Opt fan headers. Always check your manual though to be certain. I hope this hasn't confused you too much.
Making a 2000RPM fan spin at 1200RPMs though will usually depend on how good your motherboard's software is and whether it allows you to actually control the actual speed of the fans, and not just set a thermal range for operation. Most current motherboards only allow you to set a thermal range that's based on a percentage of the fan's full speed.
