will this mother board
http://www.amazon.com/gp/product/B009FC3YJ8/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
fit inside of this case?
http://www.amazon.com/Rosewill-MicroATX-Tower-Computer-FBM-01/dp/B005LIDU5S/
You posted the same motherboard twice without the case, both links are the same... Also what processor are you planning on using?
fixed it and this is the case
this is the processor
bump~
Yes, they should all fit.
