Question about 4090
Hoping this is right place to ask is it possible for a 4090 or even possibly the upcoming 5090 to run 1 1440p 165 hz monitor 1 1440p 360 and a 49 inch uw at 144 (5120x1440)
2560x1440 = 3686400 pixels
5120x1440 = 7372800 pixels
total = 14745600
3840 x 2160 = 8294400 pixels
8294400 is 56.25% of 14745600
Take a look at benchmarks at 4k resolution. Your fps will be ~half that.
If a game runs at 150 fps at a 4k resolution, on your setup it will run half that, so about 75fps.
Yes, a 4090 will be able to drive that, but even a 4090 has it’s limits when it comes to multiple monitors.
If you only want to run a single game on your UW 1440p (the 5120 one), then yes the 4090 can drive most games at high settings, 144 Hz. If you also want to include the other two screens, then expect an average FPS of ~60-75, more if you use upscaling.
I do believe a 4080 or 7900 XTX could get you 85% there for half the money, though you would need to buy a new GPU quite a bit sooner, too.
