Has anyone been actively running Qubes OS?
I am curious as to peoples experience with it.
Edit: Spelling
Edit: Spelling
I have not used it personally but
For several years, I have used Qubes OS daily as a “second computer” for most Web access. (This is being written in Qubes.) I am very satisfied with Qubes in this role. Early on, I explored moving my software development work to Qubes, but decided to keep a “regular” Linux for development. And I use other OSes as well.
Used in this way, Qubes offers a strong defense against malware which might be encountered while browsing the Web. It also provides a good way to download and work with untrusted data in a separate VM. That should significantly reduce the attack surface. But quite a bit of data is still available to those who can collect & correlate it: ISP, Google, Facebook, law enforcement, nation-state actors, etc. For Ultimate Privacy, additional measures would have to be taken.
This also “lets Qubes be Qubes”, using it just as intended. I don’t try to get Qubes to do “unnatural acts”.
Some characteristics to be aware of:
I have found Qubes to work well and reliably, except that it may not work on the newest hardware. (Qubes uses a Linux kernel which is updated periodically, but never the cutting edge.) There are frequent, often daily, updates and it is rare for these to cause problems. There is decent support & discussion online, but I don’t regard this as a strength - it can be an effort to track down correct answers to questions. C’est la net!
That’s my experience - quite good on the whole. I recommend it if it suits your needs.
I would add that Qubes has an old-fashioned look & feel, a little awkward, since it is uses XFCE for desktop. That doesn’t bother me at all, but others may have a different opinion.
Someone’s currently working and had some success getting an rx 580 and GTX 1070 to work in a VM on an alpha of the next release, discussing their issues debugging it here: Ryzen 7000 serie - #70 by neowutran - Hardware Issues - Qubes OS Forum
